Strip Path Function directly in TestStand?
I'm using TestStand 2013 an I'm searching for a "Strip Path" function, which can retrive path name and file name from a coherent path-string.
Such a function exists in LabVIEW but I didn't found any comparable in TestStand.
Kind regard
Christian
Christian
Test Engineering
digades GmbH
www.digades.com
(9,508 Views)
There is not a native one that I'm aware of.  I always use something like this:
Split((Split(Locals.Path,"\\")[(GetNumElements(Split(Locals.Path,"\\"))-1)]), ".")[0] //Get path name
Hope this helps,
jigg
CTA, CLA
testeract.com
(9,503 Views)
Accepted by topic author C.D.
To get the path of the currently running sequence (or any other ) try this in a statement :
Locals.sequencepath = Left( RunState.SequenceFile.Path, Find(RunState.SequenceFile.Path, "\\", 0, True, True) ),
To get filename from path you can use MSCORBLIB function.
Add a .net action step.
Select MSCORBLIB assembly 4.0
Select root class "System.IO.Path (not creatable)"
Select .net invocation as "GetFileName(System.String)"
Hope this helps.
Ravi
(9,475 Views)
Hi together,
thanks for all your replies. Now I've solve the request like follow:
Locals.FilePath = Left(RunState.SequenceFile.Path, Find(RunState.SequenceFile.Path, "\\", 0, True, True))
Locals.FileName = Mid(RunState.SequenceFile.Path, Find(RunState.SequenceFile.Path, "\\", 0, True, True)+1)
Kind regards
Christian
Christian
Test Engineering
digades GmbH
www.digades.com
(9,447 Views)
RunState.SequenceFile.AsPropertyObjectFile.DisplayName
Will give you the sequence file name.
jigg
CTA, CLA
testeract.com
(9,433 Views)
