Str() function: Example using "%expr"
TestStand 2016 (64-bit) on Windows 10 Pro (64-bit):
Ran across a formatting parameter in Help describing a '%expr' format code under Str() but there is no example provided and nothing was found under Examples.
Anyone have one??  I've attempted several arguments/formats but none seem any more special than what one would expect of '%s'.
The Help text reads as:
Note: Use a format code of %expr to format an expression for display. The expression must be a localized expression. Specify combinations of the following values for parameter 3 to control how the expression is formatted:
   0x1 - Format precondition-style expressions into a simpler format.
   0x2 - Insert step name comments for expressions that use unique step Ids.
   0x4 - Use shorthand for RunState.Sequence.<StepGroup>["step"] in expression.
   0x8 - Replace unique step Ids with step names.
(4,627 Views)
Str(5.67445000, "%.2f", 1, False) Evaluates to 5.67
Str(5.67445000, "%g", 1, False) Evaluates to 5.67445
I'm not quite sure what you are asking here?
jigg
CTA, CLA
testeract.com
(4,596 Views)
If you review the TS help for Str(), you will see another Note about the "%b" format code (usage is same for LabVIEW).
I was following up on this new format code of "%expr". No example was provided.
P.S. Your examples are strictly inline with normal Str() use for the %f and %g format codes.
(4,572 Views)
Accepted by PoolMaster
So I think I understand what you are asking a little better.  Thanks for clarification.
Expressions are their own unique animal in TestStand.  They are C Style syntax as well as you have access to the TestStand functions.
Let's say I have a local variable of type Expression called MyExpression with a value of RunState.Sequence.Main[0].
If I use Str(Locals.MyExpression, "%expr", 0x4, False) the return will be {NameOfStep}.
Whereas if you do Str(Locals.MyExpression, "%s", 1, False) the return will be RunState.Sequence.Main[0]
I guess it just depends on the expression and how you want it visualized.
jigg
CTA, CLA
testeract.com
(4,570 Views)
Wow.  That's very good. I would never had thought to use an Expression-type PropertyObject directly.  I use them, of course, but never considered that specific usage.  I was also curious about the descriptions used for Parameter 3 which now make sense.
It's odd, one of the attempts I made was something like:
Str( Evaluate(<existing expressionObject>),"%expr") which looked just like using the %s code (as best I recall now).  So close, yet, so far.
Excellent, excellent.  'all hail jigg'!!!
kudos^2
Dave
(4,554 Views)
