Stop the results window from showing at the end
This may seem like an odd request, but is it possible to stop the final results window coming up at the end of the test run? I still need all the results handling mechanism working because results are logged to a database and I use the MainSequenceResults property. However I don't need the actual TestStand results. I'm happy to modify the process model but can't find the right place.
Ronnie
TestStand 4.2.1, LabVIEW 2009, LabWindows/CVI 2009
Message 1 of 21
(5,442 Views)
Hi Ronnie,
Sorry, I have no answer on this. But i am forced with the same issue. I my case i need it !!!
When i did some tests trying to switch from TS 4.0 to 4.2. I realized that my (Xml)Results in
 Editor and OperaterInterface are missed ! (Internet-Explorer) Control is missing the result's file.
I am using an old TS2.0 derivation of the ProcessModel which has been only optimized over ther years.
There where no Problems on 3.x and 4.0, 4.1.1
I have compared my model with the model shipped with TS 4.2,  but i found no major difference.
Unfortunately I had no time and money to spend more time on this issue. I put it off to next year topic list.
So i am very courious on the anwers on your thread
Greetings
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 2 of 21
(5,432 Views)
There maybe a Engine.PostUIMessage(UIMsg_DisplayReport) somewhere at the end of the ProcessModel entry point sequence or at the end of the Test Report Sequence.
Otherwise you might have to modify your UI.
Regards
Ray Farmer
Regards
Ray Farmer
Message 3 of 21
(5,430 Views)
Accepted by Believer
Hi Ronnie,
I had some minutes time to visit Ni's SequentialModel
If you skip the attached step, no result will be displayed
Hi Ray,
I will try it, but changing UI make so sense because it also happens in the editor
Regards
Juergen
--Signature--
Message 4 of 21
(5,422 Views)
Hi Ray,
I have tried PostUiMessage at the end of my EntryPoint.
No report is viewed.
Juergen
--Signature--
Message 5 of 21
(5,406 Views)
Ronnie,
Juergen is correct, if you skip the Set Report step in the Entry Point you are using (Test UUTs or Single Pass), then the report string does not get attached to the execution, and therefore not displayed.  This just shows the completed execution and the report tab contains a blank report.  Is this what you're looking to do?
Eric B.
Message 6 of 21
(5,397 Views)
Juergen,
Between TestStand 4.1.1 and 4.2, the XML reporting was modified.  New XML stylesheets were included that are easier to modify and maintain, and we now encourage people to edit those stylesheets to change the look and feel of their report.  I would take a look at the new stylesheet (if you're still using the TestStand default stylesheets) and see if there were any modifications there that may prevent your report from displaying properly.
Does an XML report file still get generated and it just doesn't display properly?
Eric B.
Message 7 of 21
(5,395 Views)
Hi Juergen, Eric, and Ray,
Greetings from Southern California.
Thank you for all the good advice. Yes - I am using the Sequence Editor, and I decided to skip the Set Report step.
[I should have seen this myself - sorry!].
In an ideal world I would not have the grey window at the end - but no problem.
Thanks for all the effort you guys put into this community.
Ronnie
Message 8 of 21
(5,387 Views)
Re: In an ideal World
I'm thinking that
RunState.Execution.TypeMask |= ExecTypeMask_CloseWindowWhenDone
should close the window. However, I tested it, and it does not. I created a problem report on the issue.
Message 9 of 21
(5,377 Views)
Thanks James - good to know!
Message 10 of 21
(5,374 Views)
