NI TestStand
Specify Relative Report Path
I would like to set the directory of my report to be a relative path from where my sequence file resides using a callback. For example "..\\..\\Reports" Can anybody point me in the right direction?
(3,206 Views)
RunState.SequenceFile.Path + "\\..\\..\\Reports"
Check these out:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8FPSA0&l=en-US
https://forums.ni.com/t5/Example-Code/Customizing-the-TestStand-Login-amp-Logout-Procedure/ta-p/3619...
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,176 Views)
Select "Specify Report File path by expression" and Frame the expression in such a way that relative path is build.
(3,161 Views)
