NI TestStand
Single Pass ReportText Problem
I am using the ReportText output of a custom step type.
When I execute steps using "Run <step name>", everything works fine and  I get a text that I need (see pic1.png). However, When I execute steps using "Single Pass", I get a text that there are meaningless characters inside (see pic2.png). How can I resolve this?
(2,097 Views)
After changing the report format to ASCII Text File, I executed the steps again using Single Pass and I get the text that I need as in "pic1".
I want to get the report in XML format, but I get the characters I don't want in the text, as in "pic2". Can I convert the text I received in XML format to the text I received in ASCII format?
(2,012 Views)
Its simple to convert XML to text Data,
Explore on XML Parser.
(2,001 Views)
