NI TestStand
SequenceFilePostStepRuntimeError isn't handling errors from SequenceFilePostResultListEntry
I would like to implement custom error handling using SequenceFilePostStepRuntimeError engine callback.
I also use SequenceFilePostResultListEntry engine callback to filter some results. When the error occurs in SequenceFilePostResultListEntry, SequenceFilePostStepRuntimeError callback does not trigger.
Why is that? Can't engine callback trigger another callback?
Example in the attachment (start with A.seq).
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,385 Views)
Accepted by topic author bienieck
Nevermind. I found the answer (as always after I post...)
https://www.ni.com/docs/en-US/bundle/teststand/page/caveats-for-using-engine-callbacks.html
TestStand calls other Engine callbacks only when executing the SequenceFileLoad or SequenceFileUnload Engine callbacks. TestStand does not call Engine callbacks when executing the other Engine callbacks.
This is lame IMO ☹️
Michał Bieńkowski
CLA, CTA, CPI
(1,380 Views)
