NI TestStand
Sequence File Preload error (Teststand Not responding)
Hi all,
Teststand Seq  file   hangs while preloading
It hangs at this call  back   SeqfilePostruntimeerror   in the step  "Terminate"
any suggestions as to solve this issue
(4,981 Views)
This looks as if the step "Terminate" should include a code module which is configured incorrectly.
Can you post a sample of the behavior (sequence file and modules)?
thanks,
Norbert
Norbert
Expert: Geometry
(4,977 Views)
Thanks Norbert,
well in terminate  I use an activex   and   is similar to the  Sequencefilepoststepruntimeerror   eg in   egs
the activex  terminates the   execution.
well i restarted my pc    and it worked fine
(4,966 Views)
