Semiconductor Module and Veristand in TestStand 2024+
What is the goal for the TestStand Semiconductor Module, and Veristand Steps in TestStand. Right now the currently released versions require you to use TestStand 2023. I'm guessing this is a limitation of those things using .NET Framework, so TestStand 2024+ is out of the question.
I have multiple stations coming up, that will need to use Semiconductor or Veristand in TestStand. I would rather use TestStand 2025 if possible, is there a roadmap or timeline when Semiconductor and Veristand will support modern releases of TestStand.
Message 1 of 9
(311 Views)
Is there any feature in TS2025 that you would like to use? if not I don't see a reason not to use TS2023
Santhosh
Soliton Technologies
Message 2 of 9
(308 Views)
I'd rather use .NET instead of .NET Framework on the backend, especially since all versions of TestStand going forward will be .NET. That way I can future proof my applications, custom code, and make them easier to update to newer versions without recompiling everything.
Not to mention a lot of the report fixes in TestStand 2024+ are things my customers want (those specific things are outside of Semiconductor but in use with Veristand). Fixes like the on-the-fly reporting, pdf generation. And a big one we've had problems with is the deadlock issue with enums and LabVIEW that was fixed in 2025 Q2.
Message 3 of 9
(303 Views)
Out of curiosity, would you mind sharing what kind of application are you working on that uses both STS and VeriStand?
https://tmesystems.net/
Message 4 of 9
(251 Views)
I think he has both applications separately but would like to be standardized on TS version within the org.
Santhosh
Message 5 of 9
(246 Views)
Yup correct. Not using Veristand at the same time as the Semiconductor Module. But have different projects where Veristand is used for some, Semiconductor for another, LabVIEW/.NET for others, etc... So standardizing the year, and recommendations for customers.
Message 6 of 9
(223 Views)
Starting 2026 Q3, you will be able to use the latest versions of TestStand & VeriStand together, as VeriStand will be migrated to .NET 8. Till then we recommend you use TS 2023.
Message 7 of 9
(30 Views)
Hey Harsha,
How about the rest of the TS based workflow like STS/TSM? will they continue to be tied to TS versions?
Santhosh
Message 8 of 9
(22 Views)
Yes, STS/TSM will continue to be tied to a specific version of TestStand. I don't yet have an exact timeline (sometime in 2027) on the next update of STS/TSM is & what version of TS will be used.
Message 9 of 9
(12 Views)
