NI TestStand
Scan From String
In one of my requirement in Teststand, I want a similar type of functionality as of Scan From String in LabVIEW. Actually, I want to separate numeric and string and store them in numeric and string variable respectively from the String
e.g In the string "02 - Number is Two", I want to separate 02 and Number is Two and store it into Locals.Number and Locals.String respectively.
Also, is it possible to use the functions(e.g Scan From String) of LabVIEW in Teststand without creating a new vi? I mean to say, with the help of LabVIEW Active X automation server or using dll of LabVIEW in Teststand, can we use the block diagram functions in teststand?
(4,040 Views)
I don't know of any way to call a LabVIEW function without creating a VI. You can simply call a VI with all of the inputs/outputs of the Scan From String wired to the connector pane. You might also want to consider creating a custom step from the VI. I've done this for many utility functions including this one. Unfortunately, I no longer have access to the code since I did it for a company I no longer work for. Custom step creation is not that difficult and is a skill well worth mastering.
(4,015 Views)
(3,999 Views)
