06-25-2019 09:41 AM
Hi everyone,
I'm working on a test sequence with Teststand 2019 and i want to deploy the system in order to install it on other machines.
I used the MSI Based Installer output type and included all the drivers needed.
In the Feature Comparison for TestStand Deployment Utility build output types table given by NI, this output type Can be installed on a clean machine without National Instruments software.
But when i tried to run the installer on a machine without teststand, i'm asked to activate the license of labview.
I need to know if there is a solution to run a deployed teststand system (.exe) on a pc without teststand license
Thank you.
06-26-2019 09:08 AM
Hi aziz24,
You need a deployment license of TestStand if you want to use your sequence on another computer.
There is 2 types of deployment license:
Have a nice day!
Clement
06-27-2019 02:59 AM
Thanks a lot that was helpful
Have a nice day
06-27-2019 03:53 AM
Hi Cdkey,
I'm using Teststand 2019 in my build computer (with development license) and for my target computer i have a 2012 Teststand deplyoment license.
Is it possible to run my sequence in the target computer ? Otherwise how can i make the conversion?
Thanks in advance for your help
best regards
Aziz
