Remove programatically a substep
I'm trying to customize a Type.ini file in TestStand (4.0) with LabVIEW (8.5). I'd like adding/removing a substep to each created step type.
The method 'AddSubStep' is OK, my type.ini is updated.
But, before creating a new substep, i'd like removing all previous but an error is generated:
"Error -17331 occurred at Item is locked, protected, or in use and cannot be deleted."
I don't find a solution to remove the protection. Why can i add a new substep and can't remove it after?
thank you for your responses
(4,011 Views)
(3,988 Views)
What API are you using to remove the substeps?
-Doug
(3,959 Views)
YR42,
There appears to be an issue with the RemoveSubstep() method of the API. As a workaround you can use the following expression or equivalent API calls instead:
Locals.StepTypeReference.AsPropertyObject.GetPropertyObject("Substeps", 0).DeleteElements(0, 1, PropOption_OverrideNotDeletable)
We will look into this issue with the StepType.RemoveSubstep() method. Thank you for bringing this to our attention. Also, you might still want to read the document Aurelien posted a link to if you haven't already as it might contain information that is helpful to you.
Hope this helps,
-Doug
(3,951 Views)
Accepted by YR42
Yes doug your workaround works fine.
YR42  in attachment you can find an example with 2 methods.
1) The expression
2) Active-X steps   (this will be helpfull using Labview).
Message Edité par Nacer_M le 06-22-2009 07:53 AM
Nacer M. | Certified LabVIEW Architecte
(3,923 Views)
