NI TestStand
Reading/Extracting certain data from function output
Hi guys
I am quite lost on how to do this step, so I hope you are able to help me out somewhat. Thanks in advance!
I am using TestStand together with a different external plugin. This plugin prints out a 40 word (1 word = 4 HEX). I would like to know how I extract some of this data - in example like word 7 into in a global variable or a byte (First half of a Word)
I use like a CSP String Value Test together with the plugin, so retreive each word. How do I save this word as a variable or similar? Thanks
Please help me out. Thank you in advance!
(1,443 Views)
Are you able to post your TestStand sequence?
(1,415 Views)
Hello SercoSteveB
Sorry for the late response. If I may, I would like to clarify my thoughts.
I don't think posting my sequence would help with anything, as you do not have the plugin.
I am using an external plugin, that uses SPI communication, to extract this 40 word long key, where 1 word = 4 HEX = 16 bits.
The data I get out looks like this;
I.e. one of the tasks could be:
"Send command 'GetFlashKey' and check if word 0 is either 0000 or FFFF." How would I do this?
What I am doing right now is using 'CSP String Value Test' to extract this 40 word long key. Then I was thinking in the 'Data Source' tab to write something like this:
#NoValidation(
Len(Step.Result.String) == 160
Left(Step.Result.String,4) == "FFFF"
Left(Step.Result.String,4) == "0000"
Another question could be: "Send command 'GetFlashKey' and log words 1, 2, 3 and 4".
How would I do this? What is the syntax in order to log such things to the report?
Could you enlighten me about the correct procedure if I wanna extract certain data? I am not too familiar with TestStand and how to manipulate certain data.
I've attached the sequence just incase. Not sure whether you can use it for any. Thanks in advance!
(1,379 Views)
