NI TestStand
Create PropertyObject from a variable
Hello together,
I have an issues I cannot solve:
I have a local variable "Locals.variable" contains a string with the value "test".
I have a parameter container with several elements.
One of the elements has the name "test" -> "Parameters.container.test"
I need to access the PropertyObject of "Parameters.container.test" through the Variable "Locals.variable" value "test".
Like
Parameters.container.(Access through Locals.variable value "test").
Backround of the questions is the following task:
I read from a text file different values. These values I want to put into the parameters without matching every parameter inside the sequence. The textfile contain topic (name of the parameter) and the value.
I am using a while loop to go through the whole textfile and read every name of the parameter and match the values to the parameter inside the testsequence.
I hope my issue is clear.
Thanks in advance.
(1,288 Views)
This should work:
Parameters.Container.GetPropertyObject(Locals.variable,0)
If you actually want the actual value, you'd need to use one of the others (GetValString, etc..)
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(1,258 Views)
