NI TestStand
Read Custom Command Line Arguments When Running Sequence
I would like to be able to run a sequence file and have it accept a custom command line argument. For example I would like to run "TestSequence.seq" with the string "2710" as an argument to the sequence file (when I run via command line), which will be saved in a sequence local and used as an input to one of my VIs in the sequence file. Can anybody help me with this?
I have tried to capture the command line argument with the ActiveX module using RunState.Engine.GetInternalOption(InternalOption_ApplicationManager) & property CommandLineArguments
but I get an error popup saying the argument is not recognized.
Any help is appreciated.
(4,589 Views)
Accepted by topic author jkerrigan12
I think you can only do this inside of a UI that you have the source code for.  See this: https://zone.ni.com/reference/en-XX/help/370052W-01/tsuiref/reftopics/applicationmgr_processusercomm...
Since you don't have the source code for the sequence editor you cannot trigger that event and therefore cannot suppress the error.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,568 Views)
(4,548 Views)
Ok, I will incorporate this into my own teststand GUI.
Although it would be nice to have this option from the shipping version of teststand!
(4,538 Views)
There is a simple workaround to use custom command line arguments even for TestStand sequence editor. Just use /enableFeatures argument and specify your own "features to enable" separated by a semicolon.
e.g.
"%TestStand64%\Bin\SeqEdit.exe" /runEntryPoint "Single Pass" "<sequence_path>\test.seq" /enableFeatures param1_name;"param1 value";"param2 name";param_value
TestStand ignores unrecognized features and doesn't show error popup.
(1,557 Views)
