NI TestStand
取消
显示结果
搜索替代
您的意思是:
Re: run time interface
> Can you give me some examples where the directories are incorrectly
> stated in the manuals?
All of them. None of the LV teststand runtine files are in the stated
directories. There is a similar directory with some of the files though.
But if one tries to load the .vi that the manual says is the main
runtime file which we can modify, LabView can only find half the files
and they are just not there and not installed by the normal install
process.
>Are you making a LV Runtime Server?
Nope, just trying very basic things like using and hopefully modifying
the runtime.
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
0 项奖励
1 条消息(共 2 条)
3,532 次查看
Original NNTP post date: 7/20/1999
0 项奖励
2 条消息(共 2 条)
3,532 次查看
