Property Loader using a .csv file
I want to be able to have a single .csv file with all the properties for all my tests (which are contained in multiple sequence files), but the following happens:
I get an error (-18 user defined) during the "Property Loader" step of a sequence because my .csv file has more test steps (rows) than my sequence has test steps.
(In this case there are 4 tests defined in the .csv file, but only 2 in the sequence)
Is there a way to configure the property loader so that only the rows that correspond to tests in the current sequence are loaded.
In the attached ZIP file I have included the .csv file, my sequence file and the screenshot of the error.
(3,841 Views)
Russel -
I did not see a screenshot of the error that you spoke of. But, you can use start marker and end marker values to specify which limits to load:
StartMarker1
StepName,TxLevel,TxFreq,ULimit...
Gain_1,0,100,1,0
Gain_2,10,1000,2,-2
GvF_1,-10,,,,2,60,90,-1,-2,-1,-10
GvF_2,-20,,,,2,1000,5000,1,2,0,-1
EndMarker1
StartMarker2
Gain_1,0,100,1,0
Gain_2,10,1000,2,-2
EndMarker2
Scott Richardson (NI)
Scott Richardson
https://testeract.com
(3,841 Views)
Thanks a lot. That got me on the correct track,
For my application I had to format my file to look like the following:
GAIN_TESTS_START
StepName,TxLevel,TxFreq,ULimit,LLimit, ...
Gain_1,-50,100,1,0,,,,,,,
Gain_2,-100,1000,2,-2,,,,,,,
GAIN_TESTS_END
GVF_TESTS_START
GvF_1,-10,,,,2,100,500,1,2,-1,-10
GVF_TESTS_END
When I did this, and set the start and end data markers in the property loader page in each sub sequence, my errors went away.
(3,841 Views)
