NI TestStand
Programmaticaly inserting strings into array.
Hello all,
So I have initialised a 1d array that is set to be the size of the amount of test sockets active using the following code.
SetNumElements(FileGlobals.ReportPaths,FileGlobals.NumberOfSockets)
I then use a FOR Loop to iterate thriugh the array using the LoopCount as the index to insert the string.
Uswing the following code.
#NoValidation(InsertElements(FileGlobals.ReportPaths,"[Locals.LoopCount]",Parameters.ReportFilePath))
I keep getting an error message stating that "[Locals.LoopCount]" is out of range.
Any ideas?
(2,651 Views)
Accepted by Conor.
Solved. Don't use the TestStand API.
Do it like you would any other progrmaming language.
FileGlobals.ReportPaths[Locals.LoopCount] = Parameters.ReportFilePath
(2,648 Views)
Hey Conor,
Thank you for reporting your solution, this is really helpful!
Ingo â€“ LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
(2,529 Views)
