NI TestStand
Programmatically launch 32bit or 64bit TS from C#
I'm using the simple C#.net example to run TS sequences. I have both 32bit & 64bit TS 2019 installed.
I can use the TS version selector to launch either versions but I want to control the launch from within C#. How do I do this using the "LaunchTestStandApplicationInNewDomain.LaunchProtected(.......). Can I pass a particular argument to it that alters what TS instance is invoked.
(2,606 Views)
Accepted by topic author MisterVVC
The TestStand Engine is a per-process singleton, so it will be the same bitness as your C# app. If you want to run sequences in both bitnesses, i can think of a few options:
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(2,583 Views)
Thanks for the info - I finally got round to trying this out by compiling a 32bit & 64bit C# app and running the relevant sequences. This proved TestStand bitness is as per your description.
(2,511 Views)
