03-03-2020 10:48 AM
I'm using the simple C#.net example to run TS sequences. I have both 32bit & 64bit TS 2019 installed.
I can use the TS version selector to launch either versions but I want to control the launch from within C#. How do I do this using the "LaunchTestStandApplicationInNewDomain.LaunchProtected(.......). Can I pass a particular argument to it that alters what TS instance is invoked.
03-03-2020 12:15 PM
The TestStand Engine is a per-process singleton, so it will be the same bitness as your C# app. If you want to run sequences in both bitnesses, i can think of a few options:
Hope this helps!
Trent
03-12-2020 10:19 AM
Thanks for the info - I finally got round to trying this out by compiling a 32bit & 64bit C# app and running the relevant sequences. This proved TestStand bitness is as per your description.
