NI TestStand
Programmatically determine which entry point was selected
I'm using the default Sequential model which has two entry points, Test UUTs and Single Pass. I would like to determine in my sequence which entry point was selected by the operator. Is it possible to programmatically determine which entry point was selected, and if so where is that hidden in the massive TestStand API and properties?
I would prefer the name of the entry point to be returned.
"All truths are easy to understand once they are discovered; the point is to discover them." -- Galileo Galilei
(3,372 Views)
Accepted by topic author B.Settles
As long as you are in MainSequence then you can use RunState.Caller.Sequence.Name
otherwise use RunState.Root.Sequence.Name
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,370 Views)
jigg
CTA, CLA
testeract.com
(3,370 Views)
