Problems with Multiple Numeric Limit Test
I'm trying to use the MultipleNumeric Limit test and I have problems with it
1) Since I use TestStand 3.1, is it recommended to uses the new type template rather than the legacy one?
2) When you let TestStand creat the test code for you it gives you the following:
// The following code shows how to access a property or variable via the TestStand ActiveX API
// To use this code you must add a parameter "struct IDispatch *seqContextDisp" to this function
// and pass a sequence context to it.
// tsErrChk(TS_PropertyGetValNumber(seqContextCVI, &errorInfo,
// "Step.Result.Measurement[0].Limits.Low", 0, &lowLimit0));
I would appriciate if anybody can show me an example using that. I just don't understand it!!
Cant't I just pass the seuence context parameter as follow: 'CAObjHandle seqContextCVI' ?
(2,849 Views)
This post has been answered here.
(2,839 Views)
