05-17-2001 09:00 PM
05-18-2001 01:19 AM
05-18-2001 09:00 AM
02-08-2011 09:55 PM
Hi Ray -
I'm using TS 4.2 and i'm having this issue on one sequence file only. The "immediately go to cleanup on sequence failure" option is NOT checked in my Station Options. But when i run one particular sequence, any errors will always go to the cleanup for that sequence.
any other ideas what might cause this? Again, i'm only seeing this behavior on one of my sequences and the rest of them do not behave this way.
02-09-2011 12:56 AM
Have you checked the actual properties of the Sequence / SequencesFile or any steps that might have a Post Action step to goto to Cleanup?
02-09-2011 09:43 PM
it worked, i must have over looked it. i swear i checked that though ![]()
