NI TestStand
Problem with data transition between TestStand and LabWindows
Hello Members,
I am quite new with both TestStand and LabWindows and I have a problem like this. I have a string type variable in TestStand and I want to manipulate this data with LabWindows/CVI dll then create new variables on TestStand via this dll file automatically. I think there is no problem to insert this string into my function, inside dll file,with input parameter of function on TestStand. However, I can not solve problem about creating new variables on TestStand with LabWindows dll automatically. I searched lots of topics on this forums but I am not able to solve this issue. Is there anyone to help about this problem?
Thanks.
(2,926 Views)
Have you tried creating a "Placeholder" variable in TestStand and then return a value into that "placeholder" variable?
(2,897 Views)
As mentioned, the recommended way to work with interfaces is to provide all data (variables) as parameters.
However, in the rare incidence that you require to create a new TS variable, you can use the TS API inside the CVI module to do so. Please note that this is a more advanced topic and is part of the TestStand 2 training. Note: This is not recommended and shall, as mentioned before, be an exception, not the rule!
Norbert
Expert: Geometry
(2,892 Views)
Thank you so much, I will try these options. For now I decided to use structres and pass them to TestStand.
(2,884 Views)
You can pass data between CVI and TS as structs if you create a custom data type in TS for the struct and enable struct passing for that type. Then create a variable using that type and pass it as parameter to the module.
Norbert
Expert: Geometry
(2,879 Views)
