Problem by Message Popup Teststand
Norbert_B a écrit :
Yes, you miss-typed "step" as "setp" (red marked in the expression)......
Norbert
sorry but I also do not find button on Message Popup step when I'm writing "step.", below is a list of suggestions on teststand ( I  see only the button 1,2 up to 5)
Message 11 of 22
(3,144 Views)
Ah, seen only the typo.... there is another issue in your expression as i presumed: Delete the leading and postponing quotation mark.
Norbert
Norbert
Expert: Geometry
Message 12 of 22
(3,138 Views)
Norbert
I have removed the quotes and I tried two method, but both have the error
Message 13 of 22
(3,132 Views)
crossrulz a écrit :
Another simple option is to create an array with the possible values and then just index the value that was chosen with the button.
Locals.CanType = CanTypeArray[Step.Result.ButtonHit-1] //If the array is 0 based, you will need to subtract 1 from the ButtonHit result
I created a string in array as you can see on the attachment because my Locals.Can_Type must be equal to a string but I get an error
Message 14 of 22
(3,131 Views)
As you can see in your second screenshot, the ButtonHit equals 0 in your execution. That is only possible, if the PostExpression is not part of the MessagePopup step.
Norbert
EDIT: I see that the dialog is no runtime error, but an evaluation warning. Sorry for the confusion. Obviously, you haven't executed the sequence yet. Do it.....
Norbert
Expert: Geometry
Message 15 of 22
(3,127 Views)
Norbert
I did, but I always get an error
and I dont understand why I see  always warning Step.button0label
Message 16 of 22
(3,110 Views)
You need to tell the analyzer to ignore that error.  Use this as your PostExpression:
Locals.CanType = #NoValidation(Locals.CanTypeArray[Step.Result.ButtonHit-1])
The #NoValidation is a flag to tell the analyzer to not pre-evaluate the expression.  The ButtonHit is default to 0, but after actually running, the value will be greater than 0 since the first button will return 1.
Message 17 of 22
(3,106 Views)
sorry, I can not open the document because you do not have the same version as me and when I use your suggestion I get an error
and when I removed the # I get another error
Message 18 of 22
(3,103 Views)
Accepted by sonnyanderson
Ah, you have a version from before that function.  In that case do this:
Locals.CanType = Locals.CanTypeArray[max(Step.Result.ButtonHit-1,0)]
This will force the index to be no less than 0.
Message 19 of 22
(3,096 Views)
thx thx this functionSmiley Happy
forgiveness is that you can explain to me how you doing? that is what you used? and why ? please
Message 20 of 22
(3,094 Views)
