I am using LabVIEW 6.1, TestStand 2.0.1 running in Win98.
I have a sequence file which uses the SequenceFilePostStepFailure override obtained from the TS examples folder. When my sequence runs in the SeqEditor, everything is ok but when my sequence runs in the LabVIEW Operator Interface, the labVIEW crashes when the SequenceFilePostStepFailure sequence is executed. The crash occurs at the step 'Refresh Execution Display'.
The failure message is 'Failure: "compatexport.cpp", line 33 LabVIEW version 6.1'
Attached is a zip file with two sequence files, one which causes the crash and one where I have change to 'Refresh Execution Display' to call the method PostUiMessage instead of PostUIMessageEx, this seems to work OK. Also is a Readme.txt
file which gives a bit more details.
Any clues as to why this is happening.
Regards
Ray Farmer
Regards
Ray Farmer
