NI TestStand
Passing Values Down Through Multiple Sub-Sequences
Can someone send me an example of sending a string in a local variable in the MainSequence sequence and passing this same value down multiple sub-sequences? In other words, pass a string to sub-sequence1 and sub-sequence1 passes the same string to sub-sequence2 and sub-sequence2 passes the same string to sub-sequence3 which contains a statement step-type f(x) statement having the passed variable from the higher sub-sequences. I struggle with this all the time in TestStand.
(1,817 Views)
Accepted by TonyJ
Just use parameters.  It is really that simple.
(1,809 Views)
Then use parameters for all the sub-sequences and have local variables at the very top or in the MainSequence? Sounds simple enough.
(1,783 Views)
Accepted by TonyJ
Parameters are probably best. Another, perhaps more obscure, option is to right click on the locals you want to access in your subsequences and select Propagate to Subsequence.
(1,780 Views)
I think this is important to know that Locals propagation exists, thanks for that precision James. But in terms of readability, debug, understanding of the sequences, if you have to choose how to pass down values, I'm convinced propagation is not a good idea (IMHO).
Trick question. If I define Locals.VariableName in a sequence, with Propagate to Subsequence activated. And if that sequence calls an other on with a Locals.VariableName (same name, oops). Which one will be used in my sub sequence ? Guess what could occur if you are calling a sequence written by a collegue, of from an other team... it may be confusing.
This is why I strongly advise NOT using Propagate to Subsequence. Use Parameters.
(1,759 Views)
I'm not advocating for using it or not, but for the sake of completeness I should mention that unless you select the Allow Propagation From Caller option, a local will not be replaced by a propagating local from a caller.
(1,757 Views)
