Passing DAQmx Task Names from Main & Subsequences
Hello I was curious as to whether there is a way to transfer the DAQmx task name that is used within a subVI I call. I want to run a subseqnece that calls a subvi with a DAQmx task and then proceed to reuse that DAQmx task in another subsequence. How would I go about doing this? I am relatively new to TestStand.
(3,678 Views)
Make a parameter in your subsequence:
Then from the Sequence Call step in your MainSequence, you can pass the task into the subsequence from another variable:
Of course you'll have to pass the task in and out of your code modules as well. Don't forget to clear your task in the Cleanup step group.
If you're new to TestStand you should look through the shipping examples here:
C:\Users\Public\Documents\National Instruments\TestStand 2014 (32-bit)\Examples
Hope this helps!
Trent
(3,656 Views)
The issue that I am having with this technique is that my subvi's DAQmx doesn't appear to be generating the task name when I run the program. It generates when I run the VI when called in another main VI, but not standalone and only works when highlight execution is on. Do I need delays between writes for DAQmx? I also appear to be getting a -200088 error code each time as well
(3,646 Views)
Does that error message have any additional information with it?
It can either mean that the task is invalid/doesn't exist or that it is still executing while trying to do something else (essentially not following the 'Is Task Done' VI)?
Matt | NI Systems Engineering
(3,618 Views)
