Opening a sequence when I lauch operator interface in TestStand 3.0
I want to create a shortcut for my test sequence so when i click on it, it opens up in the custom operator interface that comes with TestStand 3.0. I have several sequence files that I would like to do the same thing too. Thanks
(3,473 Views)
The command line for the TestStand 3.0 sequence editor and operator interfaces support the below options, so try using "testexec /run MainSequence c:\myfile.seq".
Scott Richardson
testexec.exe
[/run ]
[/runEntryPoint ]
[/quit]
[/setCurrentDir]
: sequence file to open
: sequence to run
: entry point to run
Multiple sequence files, sequences, and entry points can be specified.
Quotes are required for arguments that contain a space, such as "Test UUTs" and "C:\My Documen
ts\Test Sequence.seq"
Application specific command line arguments must appear after the above supported arguments.
Scott Richardson
https://testeract.com
(3,471 Views)
Thansk Scott, i'll give it a try
(3,471 Views)
..and now, after scott's advise, I am trying to run the sequence in LOOP.
what arguments are there to add in order to run mySeq.seq in loop mode using operator interface ?
Thanks!
(3,334 Views)
