Open a .json file and store it in a string (Teststand)
Hi everyone,
does anybody know if it's possible to open a .json-file in Teststand and store the text in a string?
Thank you
Tobi
(4,048 Views)
You mean like a build in function?
(4,017 Views)
Yea, maybe a build in function or if not possible any workaround. Because I have a .json file with text in it and want to store it in a variable to search for specific words.
(4,005 Views)
I'd reccommend creating a code module returning the JSON string for storing in a variable.
Yet I don't recommend string parsing using TestStand string functions. You should use code moules for this as well!
(4,001 Views)
I have tried to inform myself about code modules but unfortunately have found very little. Does this mean the action step with which you can call python/.net/c++... scripts from the desktop, for example, or what exactly is a code module?
(3,987 Views)
Accepted by to0bi
You should've taken the course 😉
https://www.ni.com/docs/de-DE/bundle/teststand/page/code-modules.html  gives an introuction into the concept.
And there's lots of stuf to learn from in %teststandpublic%\Examples
Basically, the whole architecture of TestStand relies on calling external code to perform tests, complex calculations, ...
As far as I remember your past postings, you used command line operations and evaluating stdout. Guess you have to take the next step now and go for a real programming language or Python 😉
P.S. you can do a certain amount of programming in TestStand, but it is no programming language itself
(3,984 Views)
Hi Oli,
sorry for the late reply, I was pretty busy.
Now I did it by implementing a python script.
Thank you 🙂
(3,850 Views)
