09-22-2014 06:49 AM
Hello
We have a dedicated computer running the Offline Reesults Processing utility from TestStand 2013.
We would like to start all new development with TestStand 2014, but it looks like the TSR file generated by TestStand 2014 can't be processed by the Offline Reesults Processing utility from TestStand 2013. Is there a way to generate from TestStand 2014 the same TSR format as generated by TestStand 2013?
Best regards
Yannick
09-22-2014 07:57 AM
Why can't you use the TestStand 2014 result processing utility?
-Doug
09-22-2014 08:00 AM
Hi Doug,
Does the TestStand 2014 result processing utility can process the files from TestStand 2013? We do not want to migrate all the existing TestStand 2013 to 2014 for now...
Regards
Yannick
