NI TestStand
No comparison not available for string test?
I have a string value I read from a UUT and I want to log the value but make no pass/fail comparison. On a numeric limit test there is the No Comparison Option but not so on string test. I tried using Additional Results and logging the value but it turns it into a 2 row item and the the measurement is no longer in the measurement column. Is there a way to make a string measurement look like the numeric limit test with No Comparison?
thanks,
jvh
(3,382 Views)
Accepted by topic author jvh75021
jvh,
In the past I have just written the measurement value to the limit value. This sounds like a Testsand Ideas addition.
Regards
Ray Farmer
(3,381 Views)
@Ray Farmer wrote:
jvh,
Kool. I suppose that works if you do it in the expression phase?
(3,374 Views)
