NI TestStand
Value in sequence context in for "TestStand- Iniitalize Termination monitor.vi"
Which is the value in sequence context in for no error ??
(3,493 Views)
Accepted by topic author Oriol.Bofill
Hello Oriol,
The “Sequence Context In” specifies an ActiveX reference to the TestStand SequenceContext object that you have to pass as a parameter in the VI called from TestStand. This object is the “ThisContext” element you have in the TestStand Variable Window.
This is an easy but nice example:
http://zone.ni.com/devzone/cda/epd/p/id/5838
(3,440 Views)
Thxs a lot sendia
(3,429 Views)
