 Churlikj
			Churlikj
			11-23-2016 01:26 PM
Does anyone have experience using testand to run a full automated test cell with continous testing. I have a project in which this company bassically built an in circuit tester witha a conveyor and motor drivin clam shell. I have used teststand in the past, but was wondering about ideas on this one. I really dont want to build a custom GUI and sequencer with LabView, I would rather do this with test stand. Any feedback would be appreciated.
 ~jiggawax~
			~jiggawax~
			11-28-2016 10:56 AM
What is your main concern? Are you worried about up time?
If you code it right it should run well. I wouldn't store too many results in memory.
 CharlieRodway
			CharlieRodway
			11-28-2016 11:03 AM
Like Jigg said, my only concern would be how many results you are storing in memory.
I've run long production tests back-to-back and seen tests begin to slow down, but that was pre-TS2010 and the tests were managing a lot of data.
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
11-28-2016 11:24 AM
I am worried about the up time. Thankfully we arent storing much data.
One of main concerns is integration in with the board handler to automatically start the tests.
 Norbert_B
			Norbert_B
			11-29-2016 06:22 AM
There are a couple of ways to design an automated test start. Selection of the 'correct' way is depending on some key features like test time vs. line frequency (DUTs/time), developer knowledge and of course test system environment (e.g. connected databases, hardware, user interaction, ...).
I usually recommend two options:
1) Custom UI which uses IO Server to detect 'start test' situation (e.g. closed cover of tester when manually filled). That could be e.g. a digital trigger event which essentially presses as "Single Pass" test execution programmatically (TS button 'DoClick' method)
2) Customized Pre-UUT sequence which calls blocking into a code module which waits for the start event. This approach however requires more sophisticated planning for debugging/termination use-cases (e.g. using Termination Monitor in blocking call)
