NI TestStand
NewSequenceFile or NewSequence
When programmatically creating a sequence using LabVIEW, what is the difference between NewSequenceFile, and NewSequence?
Benjamin
(3,253 Views)
Hey BenjaminS,
From the help:
NewSequence Method
Syntax
Engine.NewSequence
Return Value
Sequence
Purpose
Creates and returns a new Sequence object.
NewSequenceFile Method
Syntax
Engine.NewSequenceFile
Return Value
SequenceFile
Purpose
Creates and returns a new SequenceFile object.
A sequence is contained within a Sequence File.  You have to have a Sequence File in order to have a sequence.  A sequence file may contain multiple sequences but a sequence is only contained within 1 sequence file.  So the Hierarchy would look like this:
Sequence File -> Sequence -> Step Group -> Step
Hopefully that clears things up.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,249 Views)
Why, yes, it does help.  I don't know why I couldn't find it in the help before.  I must have spelled something wrong.
Benjamin
(3,241 Views)
