05-16-2007 06:15 AM
05-16-2007 06:30 AM
Have you set your SequenceFile properties to use one common FileGlobals?
Regards
Ray Farmer
05-16-2007 06:42 AM
05-16-2007 12:15 PM
If you use the override callback sequence LogToDatabase in you sequencefile, then it will have sight of your Fileglobals. At the moment it doesn't unless you change the settings of the Process Model sequencefile.
Regards
Ray Farmer
05-16-2007 09:04 PM
Hi Ray,
thanks for the input. i override callback sequence LogToDatabase but no Success!!!
While debugging I found that I am getting error in SequenceFilePostResultListEntry. So I tried to override callback. But somehow it is not going into this callback!!! It always goes in default step of SequentialModel.seq.
One more observation is : This error occurs for only UUT_Result and Step_Result tables. It works fine for MEAS_NUMERICLIMIT table even without overriding the callbacks!! i.e. writing fileglobals are working fine for MEAS_NUMERICLIMIT table but not for the other two.
regards,
vishal
05-17-2007 06:29 AM
