NaN and MySQL
TestStand (3.1) can use NaN constant for NumericLimitTest.
But I log my results to a MySQL database (4.1.11) using the MySQL ODBC driver (3.51.12).
When TestStand logs the results to the database, it returns an error : the error message is very long but it says that I have an error in my SQL syntax for the STEP_NUMERICLIMIT statement.
I removed the NaN constant and it works.
I tried to use the NaN constant with an Access database and it works.
I found that MySQL doesn't manage the NaN constant. It is possible to use the 'NaN' value in SQL syntax but MySQL convert it to 0.
Can anyone confirm that ?
TestStand allows the use of the NaN constant, so I can't prevent the developpers from using it...
Has anyone a suggestion to solve my problem ?
Bruno
Message 1 of 10
(13,585 Views)
As I recall, Access logs NaN as zero. I think I saw that with Access 2000, ADO and LabVIEW. This is a mistake and a loss of information, IMO.
Message 2 of 10
(13,578 Views)
Sure this is a loss of information...
and a big problem for me and my customer.
If you saw that with Access, maybe did you find a work around that you could suggest to me ?
Message 3 of 10
(13,577 Views)
Hello bruno_p,
You will find, in the links below, documents that will sure interest you:
Sanaa T
Sanaa T.
National Instruments France
Message 4 of 10
(13,561 Views)
Bruno -
Since MySQL cannot handle the NAN value and if you are willing to convert the NAN value to a real value such as zero, I think you could use an expression in the configuration for the value being logged to the database.  Try to use the expression:
(Logging.StepResult.Numeric == NAN)?0:Logging.StepResult.Numeric
This might work.
Scott Richardson
https://testeract.com
Message 5 of 10
(13,547 Views)
log the numbers to text.
Message 6 of 10
(13,544 Views)
Thank you all.
Sanaa, I know how to use NaN constant with TestStand, but I don't know how to log it to a mysql database.
Scott, it is a good suggestion to avoid the errors. But I cannot use the zero value : this value has no sense when you generate the report again from the database.
I didn't think I could put an expression in the database configuration. It's a good information but I don't know wich value to use. It's difficult to find a value that is significant for all measurements of my customer.
Odd_Modem, the use of text results is a good suggestion. But the customer wants to keep the values in numeric format in ordrer to do some statistics.
Because mysql doesn't handle NaN value, I should find the "best" work around. So I keep all your suggestions to find the best way to answer the customer needs.
If you have other suggestions, give me them.
Thanks.
Bruno
Message 7 of 10
(13,539 Views)
Bruno -
Other than using a predefined value to represent NAN, ie. -1.0 E-308 or zero, the only option is to create a new boolean field in the table for each numeric value.  The field could be called, VALIDDATA or NANDATA.  Add a new column to the statement in TestStand using the expression: Logging.StepResult.Numeric == NAN.
Any SQL queries that get the values must also read the new field to determine whether the data values are valid.
Scott Richardson
Message 8 of 10
(13,492 Views)
Another idea: use the database NULL value to represent NaN.
To do this, specify a precondition for logging the DATA column that causes TestStand not to log the data if the value is NaN. The precondition would look like this:
Logging.DatabaseOptions.IncludeOutputValues && Logging.StepResult.Numeric != NAN
You specify the precondition in the Columns/Parameters tab of the Database Options dialog box. This requires that the column in the database be configured to allow NULL values.
Message 9 of 10
(13,470 Views)
Thanks for all your advices.
Finally TestStand uses other values than NAN that causes database logging errors : IND, +/-INF.
So I think I will use a new database column that indicates an invalid value.
I should compare the numeric result with the invalid values to log the data of this column (TestStand database configuration).
And the advice for the developpers of sequence files will be : don't use (as possible) the values NAN, IND and +/-INF.
Bruno
Message 10 of 10
(13,441 Views)
