NI TestStand
Multiple Variables for Pass/Fail Step
Hello everyone, i'm new to Teststand, and in my ATE Project, i have three variables from getting data from UUT: 1,2,3; and after a pass/fail step that if these three variables are equals to A,B,C the result is pass. This is the idea, and the test pass, but on report the result is: " additional result, fail".
The expression in Data Source of the Pass/Fail step is:
(var1 == "A") && (var2 == "B") && (var3 == "C")
Is it correct to put this expression in Data Source?
Where i' m wrong?
Thank you in advance, Giorgio
(1,299 Views)
Put your Data Source back to default:  Step.Result.PassFail
Then set your Post Expression to Step.Result.PassFail = (var1 == "A") && (var2 == "B") && (var3 == "C")
(1,293 Views)
Your expression itself is fine. You can stick that in the Data Source Expression and it won't be an issue.
The Additional Results "fail" is probably from something else you have set up on the step. Have you checked Properties -> Additional Results to see what else you are logging for the step?
(1,250 Views)
