NI TestStand
Unable to Launch LabVIEW.Application
I am running into an issue after a fresh install. The install was pushed through System Link.
The error is fixed if I run TestStand in Admin mode or in Runtime, but I do have the development license so should be able to run in dev.
I have tried, doing a repair and re-installing everything, no fix. I feel like I am missing something simple.
LV2021 SP1
TestStand 2021 SP1
Thanks.
(895 Views)
Can you try to launch LV as a non-admin user and then check if you still get the error?
When LV is launched as non-admin user, it adds the required registry keys so that TS can use LV's COM interface.
Anand Jain
NI
(865 Views)
The licenses are assigned to the user and all the users that have the licenses are also admins on the PC.
so I can login with a non admin user but they don’t have the necessary licenses to run LV.
(845 Views)
