Manipulating SequenceFile Data with DOM (XmlDocument)
I like to change some Step-data settings via xml.
I have saved my seq-file as xml. So i can access it via .Net(2.0) XmlDocument Class.
Accessing and Manipulation is working well, BUT
After saving all attributes have " " (double quotes)  Instead of Ni's  ' ' (single quotes)
so TS will not be able to open the file again !!
NI:
<teststandfileheader type='SequenceFile' fileversion='416' productname='TestStand' productversion='4.0 (4.0.0.326)' compatibleversion='4.0.0.0' buildversion='4.0.0.326' origfilepath='D:\test.seq' xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.ni.com/TestStand/4.0.0/SequenceFile">
typelist>
DOM:
<teststandfileheader type="SequenceFile" fileversion="416" productname="TestStand" productversion="4.0 (4.0.0.326)" compatibleversion="4.0.0.0" buildversion="4.0.0.326" origfilepath="D:\test_Modif.seq" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.ni.com/TestStand/4.0.0/SequenceFile"><
typelist>
Do you know how i can slove this behaviour ?
regards
Juergen
Message Edited by j_dodek on 11-19-2009 04:49 AM
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,066 Views)
Accepted by j_dodek
Yeah,
XmlTextWriter.QuoteChar did the trick!
Bad:
xmlDocSeq.Save("D:\\Test_Modif.xml");
Good:
XmlTextWriter xmlWriter = new XmlTextWriter("D:\\Test_Modif.xml", System.Text.Encoding.UTF8))
xmlWriter.QuoteChar = '\'';
xmlDocSeq.Save(xmlWriter);
Juergen
--Signature--
(4,060 Views)
Are you sure quotes were the problem? Although TestStand writes out the file using single quotes, it supports reading it in with either kind of quotes. It worked for me either way in a simple test case. If you have a case in which it is not working please let us know.
-Doug
(4,041 Views)
Hi Doug,
The only thing i changed via DOM was renaming some child elements <value>ABC</value> to <value>YXZ</value> to  of some User Steptype nodes.
After saving all Attributes has changed from single to double qoutes.
I was not able toreopen the file with TS.
When i am back in office i will write a small app
that opens a TS-file with DOM and save it back without any modification.
And check out what happens.
Maybe the Encoding.UTF8 is the trick
Regards
Juergen
--Signature--
(4,028 Views)
Hi Doug,
you are right it. It doesnt care if you are using single or double qoutes or even utf
my Test.seq(just 1 Step) is running in all ways. (Original has 400 steps inside)
But i realizsed (feeling, no speedmeasure) that single and utf are opened faster than the others.
I think i should have to way a few minutes more before posting this thread.Smiley Very Happy
Regards
juergen
Message Edited by j_dodek on 11-20-2009 01:59 AM
--Signature--
(4,021 Views)
No problem. Glad I could help clarify things.
Some additional information in case you are curious:
TestStand is expecting UTF8 encoding, so I'd recommend you keep using that. Though you probably won't notice a problem unless you are using characters from a multibyte language such as Chinese or Japanese.
I would not expect any signficant speed difference between single or double quotes. If there is a difference it should be very small (probably immeasurably so).
Hope this helps,
-Doug
Message Edited by dug9000 on 11-20-2009 10:42 AM
(4,009 Views)
