NI TestStand
Listing errors prior to running a sequence
Is there a way to display\list errors in TestStand prior to running a sequence.
For example, a section of code changes. It now has more parameters being sent to a function inside a dll.
Up until now the only way to find it to run the code, wait for it to error out, then trace where the offending parameter is.
any suggestions?
thanks
(3,713 Views)
In TestStand 4.5 and later you can analyze your sequence file and catch this.  Unfortunately before that there is no way to do so.
Check out the what's new: http://www.ni.com/teststand/whatsnew/
Here's a link to the actual whitepaper: http://zone.ni.com/devzone/cda/tut/p/id/12254
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,710 Views)
As jigg mentioned only the latest TestStand has this feature but it only analyzes the TestStand side of your sequence files. It doesn't analyse inside your code modules only the TestStand interface to the code module.
Ray Farmer
(3,704 Views)
Am I wrong or is this an add-on?
I was looking (hoping) for a solution that was in the purchased package.
Is there any other solution?
thanks
(3,695 Views)
This is part of 2010 (4.5).  It is not an add-on.
jigg
CTA, CLA
testeract.com
(3,686 Views)
Accepted by CarmineS
(3,680 Views)
