Labview Application Active X Automation Server
ActiveX configuration for LV has nothing (at least in this context) to do with DCOM settings. That being said, i ask again:
Can you access the LV Options dialog of LV 2011 on your affected system?
Norbert
Norbert
Expert: Geometry
Message 11 of 14
(3,189 Views)
If that means to go on the Tools/Options menu from the Labview interface, no i can't do it because the interface is no longer visible on this system, i can only see the process running in task manager.
Message 12 of 14
(3,185 Views)
Accepted by topic author SikS
Ok, so it really seems that LV is the origin of the issue.
Make sure that LV is not running (no LabVIEW.exe process). Please go into the installation directory of LV and rename the LabVIEW.ini file to something else (e.g. LabVIEW.ini.old).
Restart LV.
Does it show the same behavior?
Norbert
Norbert
Expert: Geometry
Message 13 of 14
(3,183 Views)
This seems to solve the problem.(unbelivable)
Thank you for your time and support.
Message 14 of 14
(3,179 Views)
