cancelar
Mostrando resultados para
Pesquisar então
Você quer dizer:
Labview Application Active X Automation Server
Resolvido!
Ir para a solução
I encoutner an issue on a system (that was previously working) when trying lo run a test sequence.(this issue occured after a power break down,)
When i am trying to run the sequence i receive the error message described below:
Unable to launch the Labview.Application Active X automation server. Teststand cannot find a Labview Development System installed in this computer.
Do you have any suggestions regarding this issue?
Thanks.
Mensagem 1 de 14
7.911Exibições
Did you check if LabVIEW starts properly?
Did you check activation of licenses?
Did you check configuration settings of LabVIEW (enabled ActiveX interface)?
If answers to above questions indicate "it should work" i recommend a repair installation of TestStand.
Norbert
Norbert
Expert: Geometry
Mensagem 2 de 14
7.885Exibições
Labview starts but just the process, i can get the interface running.
License is ok, by verifying the NI license manager.
How can i check the status of Active X interface?
Mensagem 3 de 14
7.881Exibições
So you don't get the LV window?
It sounds like you have to repair install LV.....
Norbert
Norbert
Expert: Geometry
Mensagem 4 de 14
7.879Exibições
I alreday treid that, i reparied both Labview and Test Stand and even installed a fresh copy of Labview.
Can you explaing me where i can check the status of the Labview Active X ?
if i check using the dcomcnfg.exe the pathe for the Labview points to the location where it is installed.
Also veryfing in Test Stand in the  Configure Adapter , it recongnizes the Labview Development License that i have installed.
Mensagem 5 de 14
7.872Exibições
The configuration setting of LV ActiveX access can be found in the LV Options >> VI Server.
However, i am not sure if TestStand relies on that setting.
Does this issue occur with any VI you call from TestStand or only for specific VIs? Read: Please test with a simple, newly created VI...
Norbert
Norbert
Expert: Geometry
Mensagem 6 de 14
7.867Exibições
It occurs for every VI that is loaded from Test Stand.
If i try to create a new test in Test Stand and select the Labview Adapter , i see the initializing Labview Adapter  message for a while and then i receive the error message from the first post.
Mensagem 7 de 14
7.865Exibições
Can you please post two images, one showing the error dialog, the other one showing your LV Adapter settings?
Norbert
Norbert
Expert: Geometry
Mensagem 8 de 14
7.861Exibições
Hello ,
Please find attached the required printscreens and also a print screen from the DCOMCNFG menu.
Baixar tudo
Mensagem 9 de 14
7.858Exibições
The DCOMCNFG print screen
Mensagem 10 de 14
7.857Exibições
