NI TestStand
LabView VI monitoring parallel testing sequence
Hello!
I'm running a parallel testing sequence with up to 8 tests running at the same time. The current situation leads to having 8 different LabView windows monitoring the tests at runtime, which can be messy for the users. The tests run for a great amount of time, and does not start at the same time!
I have managed to create a LabView VI that can import VI modules into subpanels (monitoring VI), so that I can have one window showing 8 different tests.
Is it possible to run this monitoring VI from TestStand and keep running until the 'Exit' button in the parallel UUT input has been clicked?
I can of course run the VI from only the first execution, but this locks the first execution to not finish until that VI is closed. I can also start the VI manually from LabView, but that is not something I want for the user to handle.
Sindre
(4,282 Views)
Solved the problem by editing the "Parallel Sequence" file properties, and run the VI from there.
(4,261 Views)
