LabVIEW version '15.0' is not installed
Hi All,
When I load an Action step and set it Agilent 34970.lvproj for LabVIEW 2015, the round RED 'I' (exclamation point) says "LabVIEW version '15.0' is not installed."
Of course I beg to differ but TestStand still thinks LabVIEW version '15.0' is not installed.
What can I do?
(5,159 Views)
What is your LabVIEW Adapter configured to?
You can check by going ot Configure>>Adapters... and select the LabVIEW adapter.
jigg
CTA, CLA
testeract.com
(5,139 Views)
Thanks for responding. 🙂
This is resolved. Not precisely sure why. My TestStand is 64-but but LabVIEWwas 32-bit. I installed LabVIEW 64-bit and a bunch of other updates and that problem went away.
(5,133 Views)
Oddly enough I had this happen to me earlier today.  I was working with a sequence file adding VIs from a LV 15 project.  One VI in the sequence randomly turned red (I'd just made the VI) with the error of LabVIEW 15 not installed.  I closed everything down and reopened it and the problem went away.
(5,101 Views)
