NI TestStand
LabVIEW Modal Dialog Hangs When Called After Message Popup in PreUUT
Possibly a bug.
In the attached is the dialog.vi example from Examples\Fundamentals\Launching a Modal Dialog\LabVIEW\Launching a Modal Dialog.seq. When this modal VI is called in exactly the following scenario, the VI will hang and LabVIEW must be force-quit:
In the PreUUT callback:
 - Call modal dialog.vi
 - Call TestStand Message Popup set to modal
It's not a 100% consistent hang, so the attached example calls the two steps in a loop. The problem seems to be midly related to execution speed -- if you mash on the enter key, the hang occurs pretty reliably. It also seems exclusive to being done in PreUUT.
Confirmed on separate PCs in two versions:
 - TS 2019 / LV 2019
 - TS 2023 / LV 2024
Message 1 of 1
(104 Views)
