NI TestStand
Custom Reports Location in Dotnet interop assembly TestStand API
We are currently working on executing our tests using the TestStand API. I’ve attached an extract of our .NET code for reference, and we have a couple of questions.
Our overall objective is to manage and run tests through an Azure DevOps Pipeline and Test Plans.
  1. Does our use case align with the intended usage of the TestStand API?
  2. We would like to generate reports (XML and HTML) in a custom directory so they can be published within the pipeline. Using Report report = execution.Report; does not appear to achieve this. Is there a recommended approach to specify a custom report output location?
Thank you in advance for your support.
Thierry
Message 1 of 1
(89 Views)
