LabVIEW.Application ActiveX automation server
I just created a TestStand program installer and installed it on a deployment computer.  It has TestStand installed on it.  I included LabVIEW RTEs in the installer.  I am getting this error.
"Unable to launch the Labview.Application Active X automation server. Teststand cannot find a Labview Development System installed in this computer."
I have looked for potential solutions, one was to rename the LabVIEW config file, but I don't have that file on the deployment computer since it only uses RTEs.
Any other ideas?
(5,827 Views)
Have you deployed the sequence editor? If so, when you go to configure>>adapters, and then LabVIEW, do you have the adapters selected?
(5,823 Views)
I have.  In the adapters config box, LabVIEW is selected.  It doesn't let me select more than one.  I'm guessing that is normal due to the radio buttons.
(5,804 Views)
Hit the "Configure..." button. You should get a screen like the following:
Do you have LabVIEW development environment selected or run-time engine?
(5,801 Views)
Ahhhhh....  Development system was selected.  Just to clarify, this should  be done on the development machine right?  Or on the test/deployment machine?
(5,799 Views)
Accepted by topic author bjenkins
Since this is a station option (particular to that machine), you need to configure the property on the deployment machine.
How are you deploying your VIs and code? Did you test your code in the run-time engine on the dev machine?
(5,793 Views)
Configuring the property on the deployment machine worked!  Thanks!
(5,745 Views)
