NI TestStand
LV 7 vi's in TestStand 2.0
Is there any issues that one should be concerned about when using LV 7 vi's in Teststand 2.0?
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(3,068 Views)
Hello -
There is no known difficulty calling LabVIEW 7.0 code from TestStand 2.0 or 2.0.1. You should be able to use the TestData and ErrorOut output parameters as you did in previous versions of LabVIEW. Mass compiling all VIs to LabVIEW 7.0 will save conversion time each time you work with one of the TestStand controls in LabVIEW but is not required.
--Regards
Elaine R.
http://www.ni.com/support
(3,068 Views)
Thanks. That is what we were assuming.
BJD1613
Philips Respironics
(3,068 Views)
