NI TestStand
取消
显示结果
搜索替代
您的意思是:
LV 7 vi's in TestStand 2.0
Is there any issues that one should be concerned about when using LV 7 vi's in Teststand 2.0?
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
0 项奖励
1 条消息(共 3 条)
3,071 次查看
Hello -
There is no known difficulty calling LabVIEW 7.0 code from TestStand 2.0 or 2.0.1. You should be able to use the TestData and ErrorOut output parameters as you did in previous versions of LabVIEW. Mass compiling all VIs to LabVIEW 7.0 will save conversion time each time you work with one of the TestStand controls in LabVIEW but is not required.
--Regards
Elaine R.
http://www.ni.com/support
0 项奖励
2 条消息(共 3 条)
3,071 次查看
Thanks. That is what we were assuming.
BJD1613
Philips Respironics
0 项奖励
3 条消息(共 3 条)
3,071 次查看
