From Friday, Oct 18th 11:00 PM CDT (Saturday, Oct 19th 4:00 AM UTC) through Saturday, Oct 19th 4:30 PM CDT (Saturday, Oct 19th 9:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
NI TestStand
Jump To Subsequence Within Main Sequence Using Post Action
No problem - out of interest, which solution did you implement?
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
Message 11 of 17
(1,256 Views)
I chose the Example #3 solution since I am not always jumping to the top step of the Main Sequence.  All 3 solutions have their benefits depending on the situation.
Message 12 of 17
(1,244 Views)
Hi!
I have more complicated case ...i need to jump for main sequence BUT to the point where it called the other sequence and continue the execution form the NEXT step,e.g. in other words it like have pointer at "parent" sequence and if something happens i want to break the execution of "child sequence" and return exactly to the next step of execution of "parent" sequence to continue the execution.
I tried to call "sequence call but it unfortunately start the "parent" sequence from the beginning...
Thank you, Yuri
Message 13 of 17
(798 Views)
Attached the picture
Message 14 of 17
(794 Views)
Attached sequence that i talked about + explanation
Message 15 of 17
(789 Views)
Hi yemelian,
Please start a new topic thread in the TestStand forum for your question, so the solution for your question can be assigned.
Message 16 of 17
(786 Views)
